99 24v heat issues
Old Aug 27, 2011 | 10:41 PM
Munger177's Avatar
Default 99 24v heat issues
I was wondering if anyone knows a good replacement 3 or 4 core radiator. I seem to have slight cooling issues. I pull a 9000lb. trailer regularly and it does get hot here in the summer (95-100) but I want to help it run as cool as possible. I've cleaned the rad myself inside and out, flushed the system, replaced the thermostat, replaced the water pump, replaced the fan clutch, but it still runs hotter than I like while pulling hills. It's not the short steep hills, it's the long pulls up lesser grade hills that's killing me! It runs up to about 230 and takes a long time to come back down to 180 although it doesn't seem to ever actually overheat. I have an edge ez on stage 3, boost fooler, s&b intake, bd valve body and T/C but nothing outrageous???? maybe someone has another idea???????? Please share your ideas, I've run out of options other than getting a bigger radiator and maybe replace the temp sensor!
Old Aug 27, 2011 | 10:42 PM
RAW's Avatar
RAW
Does your fan clutch lock up? You'll know when it does, the fan gets really loud.
Old Aug 27, 2011 | 10:51 PM
Munger177's Avatar
Default fan clutch
yeah, forgot to add that! It's been replaced too. However it does seem to lock up around 195 rather than 190. Do you know if there is a 180 clutch available? p.s. I edited the main post to add that in!
Old Aug 27, 2011 | 10:59 PM
mysterync's Avatar
Default Re: 99 24v heat issues
I just mentioned on another post, have you checked the front of the radiator for oil build up?
Old Aug 27, 2011 | 11:18 PM
RAW's Avatar
RAW
Electric fans can be turned on at any temp you like. It's an option.
Old Aug 28, 2011 | 06:28 AM
turbo20psi's Avatar
You have a cummins t-stat in there.
Old Aug 28, 2011 | 06:40 AM
Billy D's Avatar
X2 on the Cummins T-stat, my 02 ran hot with all the parts store T-stats, until I got the Cummins Here's a link for a radiator someone else had experience with, good luck
https://www.dieselbombers.com/genera...-radiator.html
Old Aug 28, 2011 | 11:15 AM
Munger177's Avatar
Yes I have a cummins t-stat, I had an aftermarket one first but it wasn't worth a crap! I've thought about electric fans but I know someone else who has them (not sure which brand) and has had cooling probs while towing as well. Maybe these BTR 4-core radiator are the way to go? Sure couldn't hurt replacing that damn 2 core stock unit!!! I looked again at the radiator for build up but there is none front or back. Thanks again everyone for the help!
Old Aug 28, 2011 | 02:38 PM
RAW's Avatar
RAW
These are the ones I want, they are 5000CFM per fan
Derale Performance Dual Electric Fans
Flex-a-lite has a max of 5500cfm for both.
262 Dodge Cummins Diesel
dwmeehan
Jan 29, 2025 12:13 PM
J. Nick
Apr 25, 2015 05:01 PM
octopusmotor
Mar 19, 2015 02:22 PM
rrough96
Feb 21, 2015 11:26 AM
Polaris04
Dec 1, 2014 08:27 AM
