EV2 fuel pressure gauge flutter
Old Aug 27, 2011 | 07:08 AM
flyhunter's Avatar
Default EV2 fuel pressure gauge flutter
Has anyone experienced erratic pressure readings after installing a FASS system?
I had a Platinum 150 pump installed on my 02 recently. The shop that did it, moved the sending unit about 2 feet from the VP in the fuel line. So the gauge is reading pressure from the FASS. ( I had previously installed the gauges from schrader valve at VP)
Since then my pressure gauge flutters between 15-18psi, non-stop. No matter how I drive or what I'm towing. idling, cruising, doesn't matter.
Here's the strange thing. The truck has been back twice, because I think they fucked something up.
1st- they installed a new sending unit, bled air
2nd- they installed a new sending unit and a snubber, bled air
BUT each time they tinker with it, the gauge will hold steady as I drive away from the shop. It's not until the following morning on the way to work that it starts acting up. The shop claims that it's normal, but I have been in alot of 2nd Gen 24's with gauges that DON'T do this.
Has anyone else seen this? How do I fix it permenatly?
Note: Not sure that it matters, but the truck goes back yet again due to fuel leaking from top of tank after a hard drive.
Old Aug 27, 2011 | 01:23 PM
01quadcab's Avatar
the gauge should be hooked up just before fuel enters the vp like you had it move it back and dampen the fuel down to the sending unit till the gauge just barely works it shouldn't flutter well mine doesn't.
Old Aug 27, 2011 | 05:27 PM
flyhunter's Avatar
Oh god! I'd have undo alot of their work to put that sending unit next to the VP again. Seeing as they disconnected and removed all of the factory parts.
If I leave it as is, what will it do to the gauge in time? I'm thinking I'll be replacing pressure gauges every couple of months
Old Aug 27, 2011 | 05:35 PM
mysterync's Avatar
Default Re: EV2 fuel pressure gauge flutter
Most folks move it back, it really won't effect the reading. You can but a snubber to dampen the fluctuations. But I wouldn't worry about moving it
Old Aug 27, 2011 | 05:42 PM
flyhunter's Avatar
Already has a snubber and a new sending unit.
Old Aug 27, 2011 | 05:46 PM
mysterync's Avatar
I would double check there work, check for a good ground and verify pressure and check for fluctuations with a manual gauge
Old Sep 17, 2011 | 08:56 AM
sa200d's Avatar
well here is my two cent worth, i called issopro, was told by a rep that it needed a needle valve to dampen the high pressure during start up. u should call issopro to find out what the part number is at a napa.
Old Sep 18, 2011 | 01:37 AM
panzer's Avatar
I did the needle valve also.......i also called ISSPRO.......they said try a mechanical gauge
that didnt work either until about a week later.......then all of a sudden wa-la it works
called ISSPRO back and asked them what it might have been....they asked if i bled it correctly and i told them i did........they responded......"here in about a month we will be bringing out a new Mechanical EV2 gauge" and that they would send me one......if they follow threw with it ISSPRO will be my only choice for gauges...thats customer service!!!!
Sorry for the hi-jack
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Jan 24, 2015 10:55 AM
