gov springs?
Old Aug 27, 2011 | 12:03 AM
94Cumminz's Avatar
Default gov springs?
can your gov springs brake or slip? i was driving and the pedal went dead and i thought the linkage broke but its not and i pulled on the throttle and nothing happend!!! so is it the gov springs or what? need help fast.... please
Old Aug 27, 2011 | 02:31 AM
BRE's Avatar
BRE
Does it still run?
Old Aug 27, 2011 | 07:34 AM
RIGGLE21's Avatar
I have seen the stud pull out that the governor springs run on
does it have higher rpm gov. springs then stock?
Old Aug 27, 2011 | 08:26 AM
mysterync's Avatar
Default Re: gov springs?
Send it to a pump shop
Old Aug 27, 2011 | 09:49 AM
RIGGLE21's Avatar
http://www.vwdiesel.net/picserv/redrotors/841_G.jpg
this might help out a bit on understanding the workings a little more
Old Aug 27, 2011 | 12:10 PM
94Cumminz's Avatar
its a stock spring just tightened 2 clicks or so. so pull the pump and send it to some one is my best bet?
Old Aug 27, 2011 | 01:30 PM
mysterync's Avatar
If there is no externally visible problems such as linkage bind or slip, I would recommend sending it to the pump shop. There is very little in these pumps that could or should be repaired by the do it yourself'er. Not to mention it would be a great time for pump mods!
Old Aug 28, 2011 | 03:35 PM
94Cumminz's Avatar
fixed it! it was the linkage at the bottom that came off.
Old Aug 28, 2011 | 03:47 PM
mysterync's Avatar
If it will pop off easily you might want to replace the ball and receiver . Even more so with a auto truck, the slight movement in the linkage can make getting the tps a little frustrating
Old Aug 28, 2011 | 11:58 PM
94Cumminz's Avatar
the ball didnt pop off. it was still on there. it unscrewed itself some kinda way
