need some help
Old Aug 25, 2011 | 09:44 PM
smokinoki's Avatar
Default need some help
well i thaught i would cover all my bases first now im stumped, truck hits around 25, 26 lbs of boost and its like it defuels or ? fuel press is 12 ish at wot and cleaned map sensor that was clean anyway, i did find corrosion on the ez connections at the map sensor, cleaned it and still the same. any ideas, the iat should be next to map but there is jst a plug and no harness so im not sure about that, oh yah no codeseither
Old Aug 25, 2011 | 10:56 PM
alwazjeepin98's Avatar
what injectors do you have? fill out your sig so we know about your truck.....
Old Aug 26, 2011 | 10:14 AM
smokinoki's Avatar
well hell i thaught i did see if this works
stock inj as far as i know
Old Aug 26, 2011 | 10:19 AM
RIGGLE21's Avatar
what does it do after it defuels? e.g. cut out,drop rpms,shake,(burn tires off j/k)
Old Aug 26, 2011 | 02:32 PM
smokinoki's Avatar
i wish it would burn the tires at a roll, no its like it hits 20 ish lbs of boost and just like it drops the boost and goes to 0 then builds right back to 20ish lbs of boost then does this over and over egt is relavent to the load at the time 8 to 1200 ish
Old Aug 26, 2011 | 05:46 PM
frosty4227's Avatar
maybe throttle position sensor?
Old Aug 27, 2011 | 07:18 AM
RIGGLE21's Avatar
Blue Chip Diesel Performance Specialists
check out this link if it doesnt help i would try to unhook that edge box i have seen alot of junk edge boxes that cause those symtoms
