No Speedometer! HELP
Old Aug 25, 2011 | 09:31 PM
elledge12's Avatar
Default No Speedometer! HELP
So i just finished taking my 97 12 valve motor/tranny/chassis and put on a 99 body using its interior and everything. I then bought a 98 12 valve wiring harness and have everything working but my speedo and headlights. I tried using the ABS sensor from the 97 and 99. So my question is why arent there any wires coming from my new harness to go to my tcase? And is that why i have no speedo? And what should i do? I'm all out of ideas and anything will help!
heres a pic just to show it off. check out the v10 on the door.
Old Aug 26, 2011 | 11:48 AM
elledge12's Avatar
Default Re: No Speedometer! HELP
Come on guys I know someone on here has to know something. Lol
Sent from my LG-P999 using Tapatalk
Old Aug 27, 2011 | 09:45 AM
bluedieselram's Avatar
sure ya got right kinda harness cuz it should plug into t case for speedo
Old Aug 27, 2011 | 09:58 AM
RIGGLE21's Avatar
the newer truck reads speed from a sensor in the rear diff. and not from the t case...do you still have the original comp installed aswell?
Old Aug 27, 2011 | 12:07 PM
elledge12's Avatar
I have the 98 pcm as well. I've heard from a few people that it uses the ABS sensor in the rear end and the one on the tcase together fot the speedometer. I'm starting to think I have a 2wd harness on my 4wd. My next question is what wires do I need to rob from a 2wd auto harness to run to my tcase for the vss?
Old Aug 29, 2011 | 03:26 PM
RIGGLE21's Avatar
man wish you was closer and i would decypher it for you hands on but it would be a huge road trip for me haha
Old Aug 29, 2011 | 06:01 PM
elledge12's Avatar
Thanks riggle but I just got everything figured out. My wiring harness is set up for the 12v+ and the cab is the ground switch. I ended up just cutting the ground wire off my headlight and wiring it to the 20 amp headlight fuse and everything works how it should. I fixed my speedometer by hooking up the 99 ABS computer. Thanks for the help guys.
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
wood2turn
Chevy/GMC Duramax 04.5-05 LLY
Jan 1, 2015 07:28 PM
cumminsgen2
Oct 16, 2014 09:46 AM
