cam bus problem.
Old Aug 23, 2011 | 07:47 PM
dcpowell17's Avatar
Default cam bus problem.
I have the following issues.
lost communications with radio
lost communication with hvac control module
lost communication with sdars
how do I check the can bus circuit to find my wire problem?
Old Aug 23, 2011 | 09:09 PM
wildbill's Avatar
Sounds like your totally integrated power module went. Can your Edge CTS check for codes?
Old Aug 24, 2011 | 07:39 PM
dcpowell17's Avatar
I can get them....
The problem started when I disconnected all power, grounds and charge air preheater. The battery cable ends were trashed so I put military grade eyelets on the cables and reattached everything with fresh wire or cable ends. I left the air charge heater and solenoid off. So the only connections I did not re-install are the two wire going to the solenoid.
burndiesel
10
Feb 7, 2023 01:15 AM
wolfriver
Mar 23, 2016 10:18 PM
jeremy01995
Sep 14, 2015 06:34 PM
May 5, 2015 01:20 PM
Cody Cain
Dec 22, 2014 01:27 PM
