Not getting fuel
Old Aug 23, 2011 | 02:28 PM
02cummin's Avatar
Default Not getting fuel
I have an 02 Cummins 2500. this truck is all stock with a rebuilt tranny, new lift pump, fuel filter, and throttle positioning sensor. When you are going about 55 in the truck it will lose all power and go to an idle untill you take your foot off the accelerator and push it to the floor. Then it will take off. I have noticed if you set the cruise over 65 it will not do it. I was told maybe injection pump, but not sure. Any help?
Old Aug 23, 2011 | 06:16 PM
cummin_un_glued's Avatar
FormerVendor
really sounds like a TPS still, have you checked the volatge?
Old Aug 23, 2011 | 07:33 PM
turbo20psi's Avatar
Was a APPS (TPS) reset done?
Did you scan for codes.
Old Aug 23, 2011 | 08:58 PM
empty wallet's Avatar
They are exactly right... I know this aint from DB, but it's a very helpful link
hmmm, didn't seem to work the first time...
APPS Reset procedure - Dodge Cummins Diesel Forum
Last edited by empty wallet; Aug 23, 2011 at 08:58 PM. Reason: Automerged Doublepost
Old Aug 24, 2011 | 08:05 AM
oudive's Avatar
02cummin,
If it gets narrowed down to being your apps, they are high dollar items through the dealership. There is an aftermarket solution called a Timbo Apps. Alot cheaper than what the dealer wants, and works great.
Here is something I copied from his site "The most common problem when a APPS sensor is failing is a "Dead Pedal" You'll be driving down the road and hit the go pedal and NOTHING. A real annoying problem. The most common codes are the 0121,0122,222,223 code.
Another issue is a surging or a bucking, this often times will not throw any codes.The other cause of the "Dead Pedal' is a failing vp-44 injector pump.
Common codes for Injector pump are 0215,0216,1688,1689"
oudive
Old Aug 25, 2011 | 01:40 PM
02cummin's Avatar
I found out yesterday it was my injection pump. thanks for the help!!
Old Aug 25, 2011 | 06:15 PM
FormerVendor
that sucks but atleast the problem is resolved
Old Aug 25, 2011 | 08:27 PM
rolfyekim's Avatar
I had the same problem with my 02 dodge and they told me that the low pressure sensor could be reset still in the truck and the injector pump didn't have to be removed. I'm trying to find out why my raptor150 went out this makes the 5th pump in this truck since I have owned it.
Old Aug 25, 2011 | 08:42 PM
turbo20psi's Avatar
If you are having problems with pumps going out the first place I would start is the electricial system alt,batteries,grounds and the voltage regulator.
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
