Plate or no Plate
Old Aug 21, 2011 | 09:08 PM
atticusfield's Avatar
Default Plate or no Plate
So i recently purschased my 94 cummins and was told that I have a no. 6 ground plate, 100 horse injectors and air dog lift pump. I have been talking to many people that are running no plate with stock injectors. Should i remove my plate all together? I dont know how much my pump is turned up. I want to squeze all the power that i can before going on. Any input would be great. Thank you all for the help.
Old Aug 21, 2011 | 11:26 PM
daveO's Avatar
Do you have gauges yet?
Old Aug 21, 2011 | 11:28 PM
Up
Just ordered pyro, fuel pressure and boost
Old Aug 24, 2011 | 08:25 AM
PowerstrokeConvert08's Avatar
scribe some mark in, pull the plate, if ya like it, run it. if you done...put it back in! long as oyu have a pyro. i found no plate to be way too smokey. I couldnt change lanes with any amount of throttle, I'd black a highway out (oh yeah...and it was HOT on EGTs). I ground a zero andput it back in and got the EGTs comfortable now, i would say I lost a little top end punch, but it is way worth it now. the best way to figure it out is start messing iwth it, really hard to screw anything up, especially if you make a few marks ss you can get it back where it was
Old Aug 24, 2011 | 02:35 PM
daveO's Avatar
Yeah I agree with what he said. I wish I would've scribed marks on mine before I messed with. Now I have to guess. Just make sure you at least get the pyro in before you start messing with it.
Old Aug 24, 2011 | 03:03 PM
Full forward man
Old Aug 24, 2011 | 04:33 PM
rollinstock's Avatar
all the way baby
Old Aug 24, 2011 | 07:26 PM
thanks for the info, ill install the pyro and try it out
Old Aug 24, 2011 | 08:48 PM
monster12valve's Avatar
pull it
Old Aug 24, 2011 | 09:10 PM
So if i go with a larger turbo at the same time that i pull it, my egt will go down, correct?
Originally Posted by monster12valve
pull it
