Need help with a coolant leak at the transmission cooler lines to the radiator
Old Aug 22, 2011 | 12:56 PM
bustedknuckles's Avatar
Default Need help with a coolant leak at the transmission cooler lines to the radiator
I took my radiator out and now I'm putting it back in.
There is coolant leaking around the transmission cooler input lines.
How does this fitting seal. Is there an o ring that I'm missing>]
What makes it seal at the radiator tank?
No takers?
All I have left to get it back on the road is this leak
Last edited by bustedknuckles; Aug 22, 2011 at 12:56 PM. Reason: Automerged Doublepost
Old Aug 22, 2011 | 02:09 PM
esetzer's Avatar
I've never dealt with this specific radiator... but all the ones i took apart in the past had an o-ring around the fitting... on the inside... of the tank where the fitting mates up to it.
Old Aug 22, 2011 | 03:07 PM
Mdub707's Avatar
Yeah, I've never had to touch the one on this truck at all...
powerstroketech87 would know, but he's not on here very often. I know he's on PS.ORG more often than here though... his name is different over there too.
Old Aug 24, 2011 | 02:33 PM
Default Update: Found out the problem
Turns out ebecanezer was right.
There are doughnut shaped rubber gaskets that sit on the inside of the tank. The cooler is inside the tank, so you have to figure out a way to get these 2 gaskets positioned around the inside flange on the tranny cooler and then hold the cooler long enough to get the cooler hose nuts started without the gaskets falling down inside the tank. I think I passed the Houdini test. It's hard on the fingers, but I managed to get it back together.
I found the gaskets at a local radiator repair shop. The guy apologized for charging me $2 a piece for them....I gave him a $2 tip. After all, he saved me a couple hundred dollars over a new radiator.
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
mcompton1973
Feb 11, 2015 12:00 PM
BubbaDT55
Dec 7, 2014 08:52 AM
FlyingDutcman
Oct 28, 2014 04:56 PM
