AC Problem
Old Aug 21, 2011 | 04:41 PM
duallycc's Avatar
Default AC Problem
I seem to be having an intermittent problem with the clutch in the AC system. When I turn off the engine (ignition key in OFF position) the clutch stays energized. I didn't notice it the first time and it drained both batteries dead. While re-installing the batteries after charging them I noticed a clicking. Found the magnetic clutch was engaging. I removed the connector on top of the AC compressor, finished connecting the batteries, and started the engine. Everything was fine except the AC clutch is staying energized even though I have the AC (and defrost) turned off. Is there a relay someplace in the circuity that might be getting stuck? Any ideas? Thanks.
Old Aug 21, 2011 | 04:54 PM
ebarresi5894's Avatar
check the soleniod (not sure if it has one) and have you ever recharged your AC?
Old Aug 21, 2011 | 06:43 PM
Crazy's Avatar
i think there A/C Relay in fuse box under the hood
Old Aug 21, 2011 | 06:50 PM
duallycc's Avatar
I'll look to see if there is an AC relay under the hood. I did re-charge the AC about a month ago as I had to change out the accumulator due to a bad O-ring on the pressure switch. It's been working great for the last month.
Old Aug 22, 2011 | 09:45 AM
if you recharge it sometimes you can put too much in and it will constantly spin the clutch wether its on or off
notice when you charged it the compressor would spin and stop. spin and stop, untill it was full and just constantly spin? if it is too much pressure it will make it spin
sounds stupid but ive seen it happen HVAC is a pain.
ALTHOUGH if there is a relay, you can see it works by taking the cap off and pushing the relay to the spool. if it spins the AC only when you touch it, its not the relay
Old Aug 22, 2011 | 11:43 PM
duallycc's Avatar
Hey;
I found the AC relay in the fuse panel under the hood. Pulled it out and beat it on the fender a couple of times. The mag clutch and the AC system is working fine, but will order up the AC relay and get it installed soon. Thanks for all of the help.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
