hits idle hard.
gota 93 that falls back to idle hard. it acts kinda like what they act like on a cold morning if you rev it up. it doesnt return to idle smooth. it falls hard then idles. its real agrivating and i wanna fix it. is it just the idle screw needing to be bumped up or is it a sticky gov.?
also noticed an exhaust leak on bottome of down pipe and a minor AFC leak. what do you all think?
I would check for air leaks in the fuel system. I deleted the fuel heater using the filter stud off an 8.3 cummins. The heater is usually prone to going bad and letting air in. I don't think the afc leak would cause problems but it could. I would make sure everything is in working order before you condemn the pump. If it is the pump then you know that the rest of the fuel system is in goo working order.
Blanton
Apr 15, 2015 06:29 PM
cdetterer
15
Dec 8, 2014 08:46 PM
