new tranny or new truck
Old Aug 20, 2011 | 12:21 PM
forgasm's Avatar
Default new tranny or new truck
ok so i have an 89 w250 4x4 with a 727 automatic, i was thinking doing a getrag swap or 47rh swap, either or is gonna cost an arm and a leg. i have to do something in the tranny department or should i just sell my truck and get a 2nd gen or gen one with a getrag. my truck has 155000 miles with 95000 miles on the new p pumped engine, just dnt know what to do
Old Aug 20, 2011 | 01:51 PM
jdbigblue12v's Avatar
i would do an NV4500 swap into your truck since you have the newer engine maybe go to a local junk yard and pull one out of a wrecked truck
Old Aug 20, 2011 | 06:16 PM
forgasm's Avatar
well what about the t case? since our front drive shaft is opposite to the 2nd gens, i would just like to get a good idea of what im gonna get into if i do this, just trying to figure out what i need to do bc the 727 is slipping pretty bad since the new pump and injectors
Old Aug 20, 2011 | 07:00 PM
white93's Avatar
You should be able to use the 1st gen t case behind the nv4500. I think you just have to remove an oil seal out of one or the other.
Old Aug 21, 2011 | 09:37 AM
forgasm's Avatar
what about adapter plate and driveshafts? if anyone has done a nv4500 swap before please add your input
Old Aug 21, 2011 | 11:03 AM
NadirPoint's Avatar
Why not get the 727 rebuilt with a shift kit, new bands, steels, whatever, and put a decent torque converter in front of it?
Probably end up being alot less time, money and hassle.
Old Aug 21, 2011 | 12:39 PM
forgasm's Avatar
i want overdrive and lockup or a manual, i farm and tow skidloaders and cattle all day long and i would like to be able to get some better fuel milage
Old Aug 21, 2011 | 12:55 PM
NadirPoint's Avatar
That's what the tighter torque converter is for. A 46RH won't give any better mileage without a tighter converter as well, unless you are running all highway miles locked in OD. That doesn't sound like what you are doing.
But I would agree the manual sounds best for your application. Just a big, expensive job doing the swap...
Old Aug 22, 2011 | 10:32 AM
1989w250's Avatar
Im just getting a nwe truck
Old Aug 22, 2011 | 12:16 PM
sootnsmoke's Avatar
What truck/year are you going to buy?
