My blinker went out (not as simple as it sounds)
Old Aug 20, 2011 | 11:23 AM
empty wallet's Avatar
Default My blinker went out (not as simple as it sounds)
So, my pass. side rear light goes out (blinker, brake, taillight)... okay, no big deal, I go buy some bulbs. Throw em in, turn the lights on, go check, tailight works, but the blinker and brake light are still dead... but if they are the same friggin bulb, how can this be happening? I chased the wires looking for anything suspicious, found nothing. Checked fuses, etc. Any ideas?
Old Aug 20, 2011 | 06:01 PM
wyodiesel92's Avatar
get a test light and probe the plug when brakes are depressed and when the turn is on and see if you've got power at the plug. if those functions arent working then look for the next connection and do the same...somewhere there is probably a corroded wire or bad connection
Old Aug 20, 2011 | 09:06 PM
aguilar_15's Avatar
Could be the little control box on your fuse panel. It's a black box lookin thing that I believe controls your blinker functions. I'll see if I canget you a pic and better description tommorow.
Old Aug 20, 2011 | 10:10 PM
wildbill's Avatar
Check all the fuses?
Old Aug 20, 2011 | 10:52 PM
mix all those ha, personally i'd check fuses then power at the tail end, go through till your pack at the panel and start checking for bad news in the fuse panel or switch on the column. iirc we don't have a fuse for left or right stops and turns, it's one fuse/relay.
may start getting to the point you may want a wiring diagram if it's not in the simple steps above
Old Aug 21, 2011 | 06:40 PM
aguilar_15's Avatar
Column switch sucks, they're expensive as crap! Hope it's a fuse
Old Aug 21, 2011 | 08:55 PM
chadcycle 2500's Avatar
yes get scematic,& test light,either broken wire or dircetional switch. the brake lights run thru this switch & are intrupted to give flash funtion because of the shared filiment for both funtions
Old Aug 22, 2011 | 12:34 AM
iceman2001's Avatar
Default left turn
Hi aguilar_15 you said something about a column switch I think this is my problem. My left turn signal sometimes blinks double time, but my bulbs are good and it seems that if I turn my wheel sometimes it will fix its self. Does this sound like a column switch going?
Old Aug 22, 2011 | 02:55 AM
MLV1234's Avatar
i have the same problem
saranay
Apr 25, 2015 12:34 AM
Feb 23, 2015 08:10 AM
7.3_powerhouse
9
Jan 17, 2015 02:22 PM
POWERSTROKEMANIAC
Jan 1, 2015 07:52 PM
Floydfan38
23
Nov 2, 2014 03:42 PM
