truck wont start! help afc spring kit install
Old Aug 20, 2011 | 02:23 AM
dipapadakis's Avatar
Default truck wont start! help afc spring kit install
so i installed the afc spring kit and put in the lighter one installed it and it started up then read the directions then realized i forgot to adjust the bolt on the back so i took it all off again and pulled the stud back so it was just touching the nut on the diphram like the instructions said and tried starting it up n it wouldnt start so i took it off and srewed the stud about a half of turn in and no results do you guys think i gotta keep screwing it in or is there something i could have fucked up in the process? would that cause the truck not too start? thanks
Old Aug 20, 2011 | 02:49 AM
BRE's Avatar
BRE
The afc will have nothing to do with the truck starting or not starting. Check the shut off solenoid.
Old Aug 20, 2011 | 02:54 AM
wow crazy to find out i had set the afc all the way back instead oof all the way forward and beleive it or not that did the trick i feel like a dumbass but i had it confused in my head when i set it back instead of forward shes moving forward now!
Old Aug 20, 2011 | 02:55 AM
BRE's Avatar
BRE
Im sorry, I may be wrong but that wasnt your problem. Either way the truck should have started, but since its started there is no sense in arguing.
Old Aug 20, 2011 | 02:59 AM
yea i thought there was no way it was the afc i didn't think that would have affected it but no worries man im just happy the s.o.b. runs its about time! thanks for the help anyways
Old Aug 20, 2011 | 09:05 AM
12vcummins96's Avatar
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
ronstop
Feb 26, 2015 09:48 AM
Gman30
Dec 27, 2014 12:46 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
