Smarty Power Levels
Old Aug 19, 2011 | 09:45 PM
EggosBrother's Avatar
Default Smarty Power Levels
Ok, so i broke down and ordered a smarty, along with 4" Flo Pro Turbo back and S&B CAI, what power levels are safe to run with a stock Automatic. Unloaded and then when pulling around 6000lbs? I know it says to not run on 1 while pulling, just trying to not fry my IP or speed up the process of the inevitable, rebuilding my tranny. I'm not looking for 800hp out of the smarty, just some mpgs and a little more bottom end. To go along with that, i do not have gauges yet, are there any EGT issues associated with my setup and the smarty at any power level with stock injectors/turbo?
Old Aug 19, 2011 | 10:21 PM
justin mccabe's Avatar
i think from 1998.5 through 2002 the smarty adds like 60hp-70hp, and if you want more power you can always stack the smarty with an edge or something
Old Aug 19, 2011 | 11:10 PM
wyodiesel92's Avatar
you should be fine running it on any level empty as long as you can see fuel pressure.....as far as towing follow their specs but i wouldn't tow without an egt gauge and fuel pressure gauge
Old Aug 21, 2011 | 01:44 PM
RollinCoal99's Avatar
the smarty can go up to 140hp level 9 not 70hp.... and no DO NOT STACK chips on stock auto. safe level to run is 1-6, once in a while you can put it up to 9 but dont leave it on that all the time, when towing you want to put it on level 2
Old Aug 21, 2011 | 01:47 PM
mysterync's Avatar
Default Re: Smarty Power Levels
Not on a VP truck, 70 rwhp max usually less, will cause power loss with big fuel trucks
Sent from my ADR6300 using Tapatalk
Old Aug 21, 2011 | 03:48 PM
Yup its more like 65hp on a VP44 truck.
Old Aug 21, 2011 | 07:46 PM
"Diesel Dawgs" Since you posted on this i'll go ahead and bug you this way, whats the usual turnaround on orders? i order CAI and Exhaust thursday then smarty on friday. sorry, just gettin antsy.
Old Aug 22, 2011 | 08:49 AM
johnyb59's Avatar
I wouldn't run over 5 empty and 3 loaded. Stock autos suck
Old Aug 22, 2011 | 09:16 AM
Usually takes 2-3 business days for shipping time.
Luke
Old Aug 23, 2011 | 12:50 PM
NC66ER's Avatar
Let me know how that flo pro sounds (and fits)....ive been eyeballin the same kit. Havent had a chance to hear one around here.
