turn off headlights
on my truck the headlights turn on as soon as i turn the key over, and i want to know if there is a way (im sure its just a wire) to make it so then i can drive around with only my parking lights on. and have my headlights turn on when i pull the light switch all the way out. thanks!
I have never heard of this personally. Sounds like somebody did some undercover work on her. I would take the switch out and use a test light or multimeter to find the wire that is used for the headlights and see what is going on.
Sounds like daytime running lights to me. Found this on another site:
1994-2002 Dodge Ram I succesfully by-passed them by disconnecting the DRL moudule (drivers side fender well black box directly below the brake booster). I cut the red/orange stripe wire then cut the red/gray stripe wire connected them together and plugged the DRL module back in. I soldered/heat shrink the wires together and installed back in the factory split loom for a clean install. This should work on all 2nd generation Rams, 1994-2002.
klein444
Jun 20, 2015 11:48 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
smokee
Feb 14, 2015 12:09 PM
smokee
Feb 7, 2015 01:27 AM
