What the hell is wrong with this thing?????
Old Aug 18, 2011 | 08:51 AM
hiboy_76's Avatar
mad What the hell is wrong with this thing?????
I got a 89 2wd and it only runs on 4 cyl, 3 and 4 are ice cold when you tought the manifold. Ive had the injectors tested, moved them to different cylinders, took the lines off 3 and 4, blew them out with the air hose, and cleaned the delivery valves out. My dad thinks its a burnt valve, and ive heard it could be something in the head of the pump, because before i cleaned the lines it would just puke some fuel out of 3 and 4 when you cracked the injectors loose, now after i blew the lines out they're fine.
So does ANYONE have an idea of what it could be????
Old Aug 18, 2011 | 09:53 AM
NadirPoint's Avatar
Not sure how you get an injector line clogged, that's a new one on me. I have to agree w/dad, probably update sig - To come: valve job...
Old Aug 18, 2011 | 10:53 AM
Begle1's Avatar
Provided that you get fuel out of all six injectors when they're cracked open and you're cranking...
Then I'd say it's time for a compression or leak-down test.
Old Aug 18, 2011 | 11:00 AM
NadirPoint's Avatar
Bet it doesn't "leak down" much because it never comes "up."
Old Aug 18, 2011 | 12:06 PM
hiboy_76's Avatar
what size adapter do i need? and where do i get it? And whats a leak down test?
Old Aug 19, 2011 | 08:43 PM
truckwrench1's Avatar
a leak down test is a set of guages that you put air into the cyl( piston up both valves closed ) it will tell you if the valves are bad or rings or head gasket it shows a percentage of the air leaking you will hear it in the intake or exhaust if its valves or blowb y tube if its rings and make bubbles in the coolant if head gasket it gives you an idea of where to start looking with out tear down
2500HeavyDuty
Price Quote - Request A Price
Aug 11, 2015 04:31 PM
jjbced
Jul 19, 2015 10:03 AM
Bob V
Apr 6, 2015 11:02 PM
Feb 13, 2015 12:10 PM
Jgloveracob
Dec 28, 2014 01:35 PM
