ABS problems
Old Aug 18, 2011 | 06:32 AM
redrocket9793's Avatar
Default ABS problems
hey guys ie been having a problem with my abs on my 97 3500 2wd automatic at a while back my abs light was on (till i unplugged it) and thought i found the reason when i had 2 holes in my vacuum line fixed that and about 3 weeks ago or so i had to stop suddenly and went into a full lock and spun across 5 lanes 6 flat spots later i dont know what it could be any help is appreciated
also i replaced my steering box, power steering pump, and hydro boost about 6 months ago
i have a shop service manual if it helps
Old Aug 18, 2011 | 07:52 AM
12vcummins96's Avatar
have you checked the sensor in the rearend to se if its bad or dirty
Old Aug 18, 2011 | 03:19 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the sensor in the rear end.... I dont even thing these trucks have ABS up front in this year
Old Aug 18, 2011 | 11:20 PM
STDiesel59's Avatar
They dont have ABS in the front. i have the same truck but 4X4 and my light is on also.will have to check that sensor. Any clue where it wuld be?
Thanks!
Old Aug 19, 2011 | 01:18 AM
never heard about the sensor ill look it up in the morning thanks guys
Old Aug 19, 2011 | 08:11 AM
it is located in the top of the diff you cant miss it
Old Aug 19, 2011 | 12:17 PM
1AMatt's Avatar
Yup. Right on top of the diff. It will be the only wires going to it
Old Aug 20, 2011 | 11:06 AM
cleaned it and checked the wires today my normal braking seems better it was wanting to lock up just with that before lets hope ABS is good again thanks again guys
Old Aug 20, 2011 | 10:53 PM
silverram323's Avatar
Default Re: ABS problems
My 95 has 4 wheel abs.
My lights are on also, next time the diffy gets serviced ill change out the sensor.
Sent from my mobile phone using tapatalk
Old Oct 13, 2011 | 09:13 AM
96dodge12valve's Avatar
i have the same abs problem thought it was a relay changed that stayed off, for 5min, then came back on. could i take the ole air hose and blow out the sensor (sorry for a highjack thread got same problem, with the parking brake on )
Thanks!
isn't under the driver side batt i could be wrong
Last edited by 96dodge12valve; Oct 13, 2011 at 09:13 AM. Reason: Automerged Doublepost
cjt8569
Sep 29, 2015 06:39 PM
Ohiocummins99
Jul 8, 2015 07:30 AM
Ol Goat
Jan 22, 2015 02:16 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
