Stick shift
Old Aug 18, 2011 | 06:20 AM
cfdavis's Avatar
Default Stick shift
My 2006 dodge3500 stick shakes alot while driving wondering if anyone else has had this problem ?
Old Aug 18, 2011 | 06:37 AM
K80's Avatar
K80
Where the shifter necks up to a larger diameter on the shifter is the rubber isolator. It may be worn, or you have something loose.
Old Aug 18, 2011 | 07:36 AM
Red_Rattler's Avatar
High Tech Redneck
Like when you hit a bump? Yea it's normal either way
Old Aug 18, 2011 | 08:28 AM
cfdavis's Avatar
It dnt matter if it's the smoothest road ever just shakes all the time way more than normal
Old Aug 18, 2011 | 09:43 AM
High Tech Redneck
Well does if feel sloppy or loose?
Old Aug 18, 2011 | 11:48 AM
cfdavis's Avatar
It's not sloppy but it ain't like it was when I bought it new neither
Old Aug 19, 2011 | 04:14 AM
Matt5005's Avatar
mine shakes all the time too, not real bad but it does
Old Aug 19, 2011 | 06:36 AM
K80's Avatar
K80
Pull the boot up, take the shifter out and put the flat end in a vice to see if thats your problem. Its very simple to remove. And you don't have to take the **** off to remove.
Old Aug 19, 2011 | 07:03 AM
cfdavis's Avatar
I'm gona check it when I get off and I'll let y'all kno
Old Aug 19, 2011 | 09:42 AM
steved's Avatar
Is it rhythmic like something inside the trans is moving it, or does it just wiggle around when you hit a bump?
