I NEED HELP!!!!
Old Aug 18, 2011 | 01:55 AM
RollinCoal91's Avatar
Down I NEED HELP!!!!
hey guys so i got my 3200 governing spring in finally but i am having problems, the truck just wont start and before you go to jumping conclusion i did bleed out the injectors and all that good stuff but she just wont fire up, i personally thing that i still have air in the line however i am not getting a good fuel flow out of the tops of the injectors when bleeding and i dont think that i am getting enough fuel to get the truck running, this would really not be such a big deal but i am leaving for college tomorrow and i need to have my truck running by tonight so if i could get some feed back ASAP that would be great thanks guys
IAN:scare2 ::ouch :
Old Aug 18, 2011 | 03:21 AM
97cummins's Avatar
One problem could be the lift pump acting up.
Old Aug 18, 2011 | 06:00 AM
RSWORDS's Avatar
Throttle arm indexed wrong? Do you have 12v key on power to the shut down sol?
Old Aug 18, 2011 | 08:24 AM
justanother92's Avatar
Deffinetly check the throttle index when i did mine i had it off by a few splines and it would not start unless you gave it some throttle then fired right up.
Old Aug 18, 2011 | 01:01 PM
the throttle index is right on the correct splines.
Old Aug 18, 2011 | 01:51 PM
RSWORDS's Avatar
You positive?
You check for 12v at the fuel shut off solenoid?
Old Aug 18, 2011 | 01:54 PM
NadirPoint's Avatar
I vote throttle index. Mine was the same when I did my gov spring and I could have sworn I had put it back correct the first time. Not.
Old Aug 21, 2011 | 11:19 AM
elalr's Avatar
i had the same problem on a tractor. it was throttle index. i was certain it was right checked it multiple times was very careful but it still was off.
Old Aug 21, 2011 | 03:54 PM
tower_ofpower's Avatar
Default I NEED HELP!!!!
Full power screw backed out too far will cause it from my experience.
- Sent from my iPhone using Tapatalk
Old Aug 29, 2011 | 10:40 PM
well guys thanks for all the ideas but some parts broke off the pump when i put it back on? dont ask me how but it did, as my family always says i could break an anval with a tooth brush. gonna put some pics of my truck on here soon before and a little after i owned it no new pics yet but ill post some oh and by the way new pump is ordered and we'll be runnin by next week
