Auto Tranny Question.
Old Aug 17, 2011 | 04:27 PM
BACONBITSFORU's Avatar
Default Auto Tranny Question.
Ok guys this truck is my first auto transmission truck Ive ever had. My question is when do I need to change the fluid? I bought the truck from a company I work for. Its in the sig, the fluid is red on the dipstick but it is WAY over the fill line.. Any ideas there? Also how hard is it to drop the pan and do a new filter. Ive heard that its better than a tranz flush. Any pointers would be great! Thanks
Old Aug 17, 2011 | 04:52 PM
turbo20psi's Avatar
Its good thats it is red,but does it smell burnt?
To check the fliud start the truck and put it in "N" this allows the pump to engage then pull the dip stick..Check level
No it is not hard to drop the pan and do the filter.
Parts needed:
ATF+4,Filter,the gasket is reuseable or pick up a new reuseable gasket so you no it is right..Beer for after the job.
The way I do a flush is that I drop the pan replace the filter,clean the pan,fill the trans up with ATF then I take the line from the trans cooler to the transmission and pull it apart at the quick fitting by the cooler and have someone start the engine put it in "N" and watch the dirty fiuld pour out into and pan. Refill transmission and repart until clean fluid is present. This flushes out the converter and VB.
Old Aug 17, 2011 | 06:29 PM
No not burnt at all and or never checked it with it in Neutral so I'll jump on it
Old Aug 17, 2011 | 06:36 PM
RollinCoal99's Avatar
dodge reccomends every 30k miles to chage filters theres 2... and fluid
Old Aug 17, 2011 | 06:37 PM
2 filters? Really I just thought it was the one in the pan...
Old Aug 17, 2011 | 07:24 PM
01quadcab's Avatar
only one filter in pan I think he has allison on his mind
Old Aug 18, 2011 | 03:29 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yup
Also I believe most filters will come with the gasket.
Old Aug 18, 2011 | 07:15 PM
turbo20psi's Avatar
Originally Posted by 1AMatt
Yup
Ture,most come with a cork gasket
Old Aug 18, 2011 | 07:56 PM
NadirPoint's Avatar
Yes, the old crap-assed cork gaskets.
Get one of the new gaskets for the 48RE and never have another pan leak.
Old Aug 19, 2011 | 01:42 PM
1AMatt's Avatar
No one likes the cork gaskets... Even with RTV they never seem to work right for me
