The Sportsmen's Lounge The New Guns, Knifes, Hunting & Fishing Section
CALLING ALL GLOCK EXPERTS
Old Aug 17, 2011 | 01:59 PM
1993firstgennewbie's Avatar
Default CALLING ALL GLOCK EXPERTS
im looking at a new guide rod for my glock 21sf and i notice there is different tentions 17lb 20 lb 22lb ect. So im wondering what the differnces are and what would be best for me i have a 3.5 ghost rocket trigger and polished internals. Also my original guide rod has a chip off it where it meets the barrel about half of the face is missing thats why i want to replace it it works fine i just dont want it to come apart while im shooting but ive put about 500 through the tube with it like that.
Old Aug 17, 2011 | 02:50 PM
daveO's Avatar
If you're not handloading your ammunition, or shooting notably light, or hot loads from the factory, it is advised you stay with the factory spring weight for your Glock. A lesser weight spring can be used with low power loads, vice versa with high power loads.
This is the one I put in mine:
Glock Stainless Steel Guide Rod - GlockStore.com
Old Aug 17, 2011 | 03:05 PM
what is the stock spring rate
Old Aug 17, 2011 | 04:25 PM
RSWORDS's Avatar
Not an expert by any stretch but I do know it's 17 lbs
Old Aug 17, 2011 | 05:33 PM
daveO's Avatar
The 17 lbs is correct for models with captive factory recoil spring systems which are silver/gray in color. Previous captive factory recoil assemblies for the 17, 17L, 20, 21 & 22 had recoil springs rated at 16 pounds.
Old Aug 17, 2011 | 05:52 PM
k ill go ahead and order the stainless 17lb spring probly the lonewolf
ive ran about 10000 rounds so far since i bought it 3 years ago and this is the first malfunction but it still works perfectly i just dont wana see what happens if the guide rod slips. it would probly be a pain in the *** to feild strip it once it does im sure id have to take the firing pin out.
Last edited by 1993firstgennewbie; Aug 17, 2011 at 05:52 PM. Reason: Automerged Doublepost
gunman41mag
Oct 8, 2015 03:37 AM
gunman41mag
Jul 22, 2015 07:36 AM
scjarena
May 6, 2015 12:01 PM
gunman41mag
Jan 17, 2015 01:05 PM
duramaxtuner
Dec 10, 2014 01:42 PM
