1999 wont start in warm weather??
Old Aug 17, 2011 | 11:08 AM
moparious maximus's Avatar
Default 1999 wont start in warm weather??
A friend is having a wierd issue with his truck so I thought I'd post a question about it. This is a stock '99 3/4 ton cummins, starts just fine if its cold enough for the grid heater to cycle but as soon as it warms up or is just plain hot outside.......no start, cranks over fine just no fuel.
The dodge dealer is blaming the ECM and they could very well be right but to me this problem screams simple problem, bad ground, undervolt to the VP, fuel draining out of the VP.
Sounds kinda like this,
https://www.dieselbombers.com/24-val...-no-start.html
Thanks
Old Aug 17, 2011 | 03:57 PM
justin mccabe's Avatar
i know this isnt about your topic but i saw in your sig you have the edge ez i was wondering how you like it and if it throws good smoke.
Old Aug 17, 2011 | 05:42 PM
panzer's Avatar
sounds like a classic vp44 going out
thats exactly what mine was doing
before i changed it i could only drive the truck once a day
and thats if the tempature was below 50*F
Old Aug 17, 2011 | 06:38 PM
RollinCoal99's Avatar
bad VP and or change lift pump and might save its life, either way if it has a stock lift pump recomended to be changed
Old Aug 17, 2011 | 07:10 PM
RAW's Avatar
RAW
Generally hard starts when warm are caused by a cracked diaphragm in the VP44. Hope its something else though.
Old Aug 18, 2011 | 07:41 AM
Yea for what it is the EZ is a good box, definently helps the lower rpm's alot, doesnt smoke much but it will a little if you try. Just a trick that I do with the edge boxes like the EZ if you leave the mapp sensor unplugged the edge fuels at low boost harder yet, a little more grunt and smoke.
Looks like there might be bad news for my buddy huh.
Bigredpowerstroke
Aug 14, 2015 10:31 AM
PeteBug
Jun 11, 2015 12:16 PM
tommyboy
May 6, 2015 04:50 PM
cooler364
Mar 26, 2015 10:58 PM
ronstop
Feb 26, 2015 09:48 AM
