tranny hesitation
Old Aug 17, 2011 | 12:15 AM
redwood logger's Avatar
Default tranny hesitation
my A518 in my 93' does nothing when you first put in drive or reverse when its cold upon start up, then when you give it throttle it shutters slightly while getting going. after that its all good the rest of the time im driving it. It does take more than normal throttle to get it going at first also (even more than the normal worthless non lock up take off) and it is full of fluid and tranny temp gauge always reads cool. could this be fixed with band adjustment?
Old Aug 24, 2011 | 12:30 AM
kieron_kohlmann's Avatar
Adjust the front band.
Old Aug 24, 2011 | 12:42 AM
H.R.D's Avatar
I second a band adjustment.
Old Aug 25, 2011 | 11:26 PM
thumpertrev's Avatar
This is a common situation with the A518. The manual valve does not allow fluid flow through the torque converter or cooling lines while in park. Perfectly normal. It is remedied with a very cheap manual valve that allow flow. What you have is converter drainback.
Old Aug 25, 2011 | 11:38 PM
tower_ofpower's Avatar
sounded like drain back to me too, band adjustment could still do a world of good. simple enough; before you drive anywhere skip right to neutral momentarily then down into drive. get the juices moving before trying to go anywhere.
Old Aug 26, 2011 | 11:27 AM
RSWORDS's Avatar
Yep, tranny draining, common. Nothing to worry about.
Old Aug 26, 2011 | 06:42 PM
crazy clem's Avatar
Buddy has dtt trans and convertor they recomend starting it in neutral. Maybe thats why my trans seems to take so much fluid at filter fluid change?
InheritedDiesel
Jun 3, 2015 09:39 PM
peterbilt
Chevy/GMC Duramax 06-07 LBZ
Apr 8, 2015 10:33 AM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
Ol' RED!
Dec 11, 2014 10:00 AM
