Best oil for 91.5 Auto trans with O/D??
Old Aug 15, 2011 | 03:22 PM
flyingcrodeo's Avatar
Default Best oil for 91.5 Auto trans with O/D??
I have a 91.5 Dodge Power Ram 350 single wheel 4x4 with and auto trans with O/D. What's the best oil for the trans plus additive's? And also it takes me forever to get up to speed I can floor it and my motor is reved up but it takes forever to get up to speed. Could this be because of a worn out torque converter? Any idea's would be awsome. Thanks
Old Aug 15, 2011 | 03:27 PM
1arock's Avatar
I run Valvoline ATF+4 full synthetic. I would say a tighter converter would help you alot. Do you have a temp guage. I had my factory converter tightened up and now it seems a lot stronger on takeoff. Rocky
Old Aug 15, 2011 | 03:54 PM
MossBack's Avatar
Default Re: Best oil for 91.5 Auto trans with O/D??
Try some Lucas trans oil I tossed that in my truck and firmed up the shifts after I over worked my auto a couple times.
Sent from my PC36100 using Tapatalk
Old Aug 15, 2011 | 11:07 PM
I was thinkin putting a new BD torque converter and deeper oil pan but you think just having it tightened up would work? Is it very expensive to have done? If not then i'll have it done just to try it and if it dont help like i want it to I might just get the BD. Thanks
Old Aug 18, 2011 | 12:22 PM
91w250's Avatar
i also use valvaline full synthetic. seems to keep the temps low.
Old Aug 26, 2011 | 03:02 PM
Thé Güy Øn Thē Çòûch's Avatar
Can u tell me where I can get mine tightened up??
Old Aug 26, 2011 | 05:43 PM
frosty4227's Avatar
i run a spec right converter, costs more then the bd but is way better and custom built to your truck
and i run b and m quick shift fluid
Last edited by frosty4227; Aug 26, 2011 at 05:43 PM. Reason: Automerged Doublepost
Old Aug 26, 2011 | 05:45 PM
Can u send me a link so I can check it out?
DieselDan_5.9
Jul 30, 2015 07:05 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
kydieseltech
May 28, 2015 05:00 AM
apehangerjoe
Mar 26, 2015 03:01 AM
countryboy040993
22
Nov 12, 2014 11:25 AM
