Low boost s400 HELP
Old Aug 14, 2011 | 08:49 PM
Martinhorn's Avatar
Default Low boost s400 HELP
I've got a 99 ctd with 150 air dog 150 injectors juice with attuide hot unlock it's auto with a A&A valve body head studs and a schield built 66mm s400 I bought the truck already built minus the vb and injectors but here's my prob at 34psi it's like it hits a wall and won't make any more boost I've checked the obvious like boost limit on juice loose air intercooler piping it's not running outta fuel plenty of black smoke at 34 psi any help would be appericated.
Old Aug 14, 2011 | 09:47 PM
RAW's Avatar
RAW
Your running an S400 as a single?
Old Aug 14, 2011 | 11:59 PM
H.R.D's Avatar
Rite
Need to adjust your wastegate.
Old Aug 15, 2011 | 12:25 AM
01quadcab's Avatar
what s400 is it? I would say you need more fuel but really you need a top charger to make a set of compounds. I only made 40 psi out of my 475 with my lightning III injectors and 85 psi overall
Old Aug 15, 2011 | 04:33 PM
Martinhorn's Avatar
It's there pn 411102 says it's good to 850hp 198ex housing I'm having a s300 built now to put with it I'm looking at soure auto for piping that I can buy and finish myself I think that's about the cheapest way to get the piping. I just thought that thing would make more boost by it's self
Old Aug 15, 2011 | 11:07 PM
RAW's Avatar
RAW
Cheapest way is to buy exhaust pipe in 45's and 90's and do it yourself. That's what I did.
Old Aug 16, 2011 | 07:15 PM
Martinhorn's Avatar
Did u build support bracket for your bottom charger
Old Aug 16, 2011 | 09:59 PM
RAW's Avatar
RAW
I did not, I have a very beefy hot pipe.
Old Aug 17, 2011 | 04:23 PM
Martinhorn's Avatar
Any help would be app. I've got all the elbos and components at hand my freind owns a exhaust shop Pics dimensions parts thanks only thing I'm gonna buy is the s300 exh. Flange and 400 comp flange I think I can build the rest from looking at every one else's kits looks like the hot pipe is 4" what about comp pipe is it 4" and tapers to 3"?
Old Aug 17, 2011 | 10:10 PM
cummin_un_glued's Avatar
FormerVendor
i'm running a S474/74/.90T4 as a single and i'm seeing a max of 48psi on a hard launch and 42-45 on the street and thats with the largest scheid cam i could run on stock pistons....but the truck is ppumped with 7x12 injectors
imo to street a S400 as a single a cam is a must
