Fass Fuel Leak
Old Aug 14, 2011 | 06:22 PM
doombugie's Avatar
Default Fass Fuel Leak
After a year of installing my Fass pump it started to develop a leak around the fuel filter, then I thought the O-ring was bad so I bought a new filter and lube the O-ring with diesel then cleaned the surface of the fuel plate, but it still didn't fixed the problem. I'm running out of ideas where to trace the leak. Any ideas or tips are greatly appreciated.
Old Aug 14, 2011 | 06:35 PM
RAW's Avatar
RAW
How have you checked for the leak? If you turn the key to run, and just bump the starter, the FASS should run for about 25 seconds. In that time you could look while there is pressure in the lines.
Old Aug 14, 2011 | 06:43 PM
doombugie's Avatar
I cleaned the surface with Brake cleaner, after I bump the starter there wasn't any trace but if I drive the truck for about 1 - 3 miles then it begins leak. Which seems like its coming from the fuel filter i'll post a picture of it when I get home.
Old Aug 14, 2011 | 06:58 PM
RAW's Avatar
RAW
Only one filter on that set up? What series is it?
Old Aug 14, 2011 | 07:17 PM
doombugie's Avatar
There's 2 filter a water separator and a fuel filter and its Titanium series.
Old Aug 17, 2011 | 11:51 AM
doombugie's Avatar
Update after I sent some pictures to Fass tech support they thinks its the fuel manifold but can't figure out which one is the manifold or is the fuel plate the manifold ?
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
