quadzilla fueling issue
Old Aug 14, 2011 | 05:22 PM
skyler1101's Avatar
Default quadzilla fueling issue
im having an issure where i am custom tuning my quad adrenaline 4k and ill turn pump max all the stuff up and ill hammer down in third full throttle then shift to fourth full throttle and it goes like a raped ape but then if i let of the throttle and put it in neutral and dont touch the throttle the truck will literally die going down the road this is only if i hammer it and go wot ?? any suggestions
Old Aug 15, 2011 | 01:29 PM
D-LUX's Avatar
your asking to much from the pump and putting air into the injector lines.. VP pumps do not like to be hammered on and then let off all of a sudden it will always kill it
Old Aug 15, 2011 | 10:12 PM
skyler1101's Avatar
what the hell how does air get in
Old Aug 18, 2011 | 10:14 AM
Kraemer's Avatar
air is not getting in your lines unless you have a very low fuel level (E) and are locking up the brakes and then trying to go full fuel.
the way your describing your issue doesn't help... you say you go full fuel in third, grab fourth, then let off the throttle and put it in neutral? What is the point in that? OR, are you grabbing fourth, and the truck starts to die so you have to put it in neutral?
does it do it on other tunes, or only your "maxxed" settings?
Old Aug 18, 2011 | 03:44 PM
skyler1101's Avatar
it does it mainly on my maxed settings and its like lets say i hammer down in third and i pull it out and go neutral and brakes for an upcoming stoplight it will die
Dec 10, 2019 10:10 AM
JKinni
13
Sep 5, 2015 11:09 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
norcal6.5
Dec 7, 2014 07:04 PM
Oct 23, 2014 08:10 AM
