Electronics or Injectors?
Old Aug 14, 2011 | 02:00 PM
zach2's Avatar
Question Electronics or Injectors?
Hey guys! I need advice for more power. My question is this: To ditch my mild Hypertech tuner and get a more aggressive module? Or, keep the Hypertech and go with maybe 100hp injectors?
Old Aug 14, 2011 | 02:20 PM
cummin_un_glued's Avatar
FormerVendor
keeping the hypertech and adding injectors will give you the most options
even the most aggressive module is only going to gain you 60hp more
Old Aug 14, 2011 | 02:45 PM
zach2's Avatar
Thanks for the response! You mean 60hp more even with Edge Comp or Quadzilla? Tell me more about the options with injector upgrades please.
Old Aug 14, 2011 | 04:40 PM
turbostang7's Avatar
Default Re: Electronics or Injectors?
Get both injectors and a module , I would go with the module myself, I ran a small downloader with some 100 sticks and then swappethe stockers back in and ran the adrenaline, it was way better stickers with adrenaline.
Then when I swapped in the bigger injectors it really woke it up haha
Sent from my DROIDX
Old Aug 14, 2011 | 05:07 PM
zach2's Avatar
I appreciate the info. Another issue that I'm facing with that type of module is I already have mechanical gauges that I want to keep using. Any suggestions?
Old Aug 14, 2011 | 05:13 PM
FormerVendor
if was going to put a larger module in i would use an edge comp to keep your mech gauges but heres the thing about the larger boxes they all tap the pump wire to get the extra hp (120hp comp vs 60hp hypertech) which can lead to vp44 failure, no not allways but yes it can thats why nobody will warrenty a pump that has been tapped
yes you could do a larger box and larger injectors but i'm assuming that you have a stock charger and that is going to be your limiting factor at this point, more fuel dosnt always mean more power if you cant burn it all
100hp injectors is going to be the largest injector you will be able to keep cool towing with a stock charger
Old Aug 14, 2011 | 05:42 PM
zach2's Avatar
I have read alot of negative issues with tapping the pump wire. I'm not crazy about the idea and that's the main reason I'm researching power gains with injectors. The stock turbo has limitations too. A turbo upgrade is not in my plans. That being said, I am still stuck needing advice please. Thanks!
Old Aug 14, 2011 | 09:43 PM
FormerVendor
so add 100hp injectors with your hypertech
Old Aug 14, 2011 | 11:13 PM
agreed if you aren't going to change the turbo then stick with some bigger sticks and the hypertech, get either a boost elbow or j-hook depending on weather you have the hx or hy turbo and a boost fooler for it and you should be good to go
Old Aug 14, 2011 | 11:51 PM
1st_gen_puller's Avatar
agreed... get some bigger injectors... then think air... exhaust, intercooler, the such.. then get it all to the ground with a good clutch/tc.. whatever it may be..
