Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
white smoke at idle
Old Aug 13, 2011 | 11:40 PM
CRAZYHUNTER's Avatar
Default white smoke at idle
i just bought a 2004.5 its got the LLY in it...just recenty i was at a stop light, my girlfriend noticed some white smoke coming from the exhaust. i took it to a friend he put a computer on it.. the truck isnt throwing any codes and it only smokes when idling in gear. if i put it in nuetral or park then the smoke quits.... any ideas? when i see white smoke i think head gasket blown? but if that was the problem it would smoke all the time righ?
Old Aug 14, 2011 | 12:52 PM
cummin_un_glued's Avatar
FormerVendor
sounds like bad injectors but could also be the EGR cooler leaking coolant into the intake but thats not as common on the LLY as it is the 6.0 powerstroke
i would check injector balance rates with it in gear since it seems to make a difference
any cylinder plus or minus 4.0mm3 in gear most likly means bad injectors
Old Aug 14, 2011 | 09:54 PM
thats what everybody else ive talked to says.. i was kinda hoping it was just some crap in the fuel or crappy fuel but all signs are leading to injectors now
Old Aug 21, 2011 | 11:13 PM
95powersmoker's Avatar
Moved to the correct forum
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
Jmrobinson
11
Aug 21, 2015 09:54 PM
sgreen3
Feb 24, 2015 03:34 PM
