06 six speed tranny in a 99 auto?
Old Aug 13, 2011 | 10:01 AM
mike12321's Avatar
Default 06 six speed tranny in a 99 auto?
is it possible to do this swap if so what mods would be necessary. i can buy the tranny and t case for 800 and id love to have manuel over auto
Old Aug 13, 2011 | 10:53 PM
cummin_un_glued's Avatar
FormerVendor
other parts needed-
trans mount
drive shafts modifed 4.5" each since the 6sp is longer
get a southbend clutch so that you get the flywheel and all
clutch hydros
clutch ped
pcm reflash
rewire N safty switch
rewire reverse lights
interior parts
dash cluster
steering colum plastic covers
yes its possible....doing one right now
Old Aug 14, 2011 | 09:14 AM
mike12321's Avatar
so it would bolt up to a 24v no problem, i am not worried about any interior parts, whats a pcm flash and were can i have it done
Old Aug 14, 2011 | 11:49 AM
FormerVendor
yes a G56 trans will bolt up to a 99 24v engine plate...you may have to use a starter spacer tho depending on the clutch you use and the 4.5" measurement would be wrong thats for a NV5600 trans not a G56
Old Aug 15, 2011 | 08:23 PM
mike12321's Avatar
ok well any idea where i can have te pcm flashed
Old Aug 15, 2011 | 08:36 PM
RollinCoal99's Avatar
dealer can flash for you i think
Old Aug 15, 2011 | 10:45 PM
FormerVendor
yes dealer can do it and runs around $100
Old Sep 28, 2011 | 09:43 PM
Coilroller's Avatar
I did same conversion in 99 2wd and I didn't flash mine and every thing works fine
Old Sep 28, 2011 | 10:13 PM
FormerVendor
yeah recently found out that 01-02 autos are the only ones that need flashed and the dealer cant do it but bob wagner can
89Cummingspower
May 16, 2015 01:11 PM
TNTPrime
Jan 5, 2015 06:13 PM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
Montz
Nov 12, 2014 05:10 AM
Tower crane guy
Oct 22, 2014 06:04 PM
