99 Spitting and sputtering
Old Aug 12, 2011 | 05:20 PM
6.5L's Avatar
Default 99 Spitting and sputtering
My buddy hopped in his truck took off fine and just died starts back up idles fine put when you push the accelerater it spits and sputters and wont climb up above 1000 rpm i changed the fuel filter and still running like **** any ideas on what it might be? lift pump kicks on..Any suggestions would be helpful
Old Aug 12, 2011 | 06:39 PM
empty wallet's Avatar
Scan for codes. Does he know his fuel pressure? whats he got for fuel system mods?
Old Aug 12, 2011 | 06:53 PM
6.5L's Avatar
Check engine light came on will scan for codes... truck is stock besides exhauset and quadzilla xzt drag comp
Old Aug 12, 2011 | 07:31 PM
turbo20psi's Avatar
Sounds like the TPS or injection pump..
Old Aug 13, 2011 | 05:45 PM
skyler1101's Avatar
injector run cummins brand injector cleaner throught it
Old Aug 5, 2012 | 07:36 AM
Dennis Paul's Avatar
did you find out what your problem was? My 99 is acting exactly the same. Fuel pressure is good (16), using blue chip diesels troubleshooting guide, the injector pump checks good. Could it be the ECM not telling the injector pump to accept more gas. Thanks for all your help.
Old Aug 9, 2012 | 06:57 PM
Had a friend read my codes. It came up 1688 (death code). Replaced the IP, everything seems OK now.
