intermitent down shifting problem
Old Aug 12, 2011 | 01:21 PM
connie chandler's Avatar
Default intermitent down shifting problem
My 1996 Dodge 5.9 cummins is having issues with shifting. When I accelrate to about 30 miles per hour, it tries to shift to overdrive, but then downshifts instead. If I ease off the accelrator, it will then shift up to high gear. I don't know if this is a transmission problem or an engine problem. The transmission is rebuilt about 20,000 ago. Any suggestions?
Old Aug 12, 2011 | 06:35 PM
cummin_un_glued's Avatar
FormerVendor
check the wiring harness near the alt bracket, also BD sells a resistor that helps with that
Old Aug 12, 2011 | 07:19 PM
95powersmoker's Avatar
Moved to the correct section.
Old Aug 12, 2011 | 11:24 PM
lodal cummins's Avatar
mine did the same thing picks up noise , i wrapped the harness above the alternator with tin foil and electrical tape. never had that problem again!!!!
Old Aug 15, 2011 | 11:41 AM
Default thank you
Thanks for the advice about the tin foil and electrical tape. I'll try it.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
SixSpeed
Jan 11, 2015 01:41 AM
Oct 14, 2014 03:30 PM
