70mph what rpm
Old Aug 12, 2011 | 12:00 PM
cumminsblazer's Avatar
Default 70mph what rpm
I was hopping you guys out there can let me know what your rpm is at 70 mph and what tire size and gears you got this would help me out I'm trying to see if I have to low of gears
Old Aug 12, 2011 | 12:25 PM
NadirPoint's Avatar
1700rpm @ 70mph with 34" tires, 4.10 gears and the Gear Vendor in 5th over.
Old Aug 12, 2011 | 12:38 PM
Glantz496's Avatar
2009rpm @ 70mph with 32" tires, 3.55, and stock G360 in fifth
Old Aug 12, 2011 | 12:42 PM
Gear vendor lucky!!! I don't have the room for one
Reason I'm asking is cause I got 37" tires 4.10 and at 60mph I'm doing 2000 rpm and I don't want to hurt my motor but I would like to go 70
Last edited by cumminsblazer; Aug 12, 2011 at 12:42 PM. Reason: Automerged Doublepost
Old Aug 12, 2011 | 12:45 PM
Glantz496's Avatar
They weren't meant for speed to begin with...I keep mine at 65mph for the most part on interstates and such
but if you can find a cheap 3.55 rearend then go for it just make sure you get one for the front end too if its 4x4
Old Aug 12, 2011 | 01:27 PM
1STGENFARMBOY's Avatar
12V VE cummins will run 2,500 rpm all day long, all week long, all month long.
Old Aug 12, 2011 | 01:40 PM
sootnsmoke's Avatar
Is that correct? The reason I ask is because the ratio/rpm calculators out there always put my motor at 2000 RPMs at 60 MPH with 235/85R/16 tires with 4.10 gearing in 5th with G360 trans? With 37" tires and 4.10s I would think you would be at a lower RPM than 2000 unless your gearing has been changed to lower than 4.10
Old Aug 12, 2011 | 01:49 PM
Glantz496's Avatar
automatic trans maybe
Old Aug 12, 2011 | 02:06 PM
NadirPoint's Avatar
Yeah, something don't sound right. I'd think an OD trans much more than 1-1 in top gear would get the final drive rpm down better than that with 37" tires.
Old Aug 12, 2011 | 08:26 PM
crewcab59's Avatar
when i did my swap the truck had 4.10 gears with the a518 and yes about 60 mph it is about 2000 rpms is right, for pullin my 5th wheel it was nice. but daily driver it sucked, i put in some 3.73s now its about 1800 @ 70 mph,not so good for pullin but OK. i then tried 3.54s, it will flat haul *** but pullin sucked, (if you don't plan on pullin anything then i would go with them. to get the 3.54s in the back i put in a Dana 60 (14bolt does not have 3.54 option ) I went back to the 3.73s for all around use. 60 mph is about 1600 rpms in O/D hope this jiberish makes sense
