Need opinions on stock springs
Old Aug 11, 2011 | 01:37 PM
Sudia247's Avatar
Default Need opinions on stock springs
Im rebuilding a truck right now and Im about to put the front axle back under the chassis and I wasnt sure on what springs I should put in. The springs that were originally under the frame were stiff as hell. When it was just the axles and suspension on the frame I tried bouncing it and it was so stiff only the tires flexed and made the axle hop off the ground, no suspension compression! I also have a set off my donor truck that are soft and actually compress, but I dont want too soft were It bottoms going over a few bumps....
Does anyone have any advice??
By the way Im referring to the front springs.
Old Aug 11, 2011 | 03:36 PM
South Tx Coal Roller's Avatar
A 12 valve engine weighs right around 1k lbs so the springs are going to be really stiff with the engine out.
Old Aug 11, 2011 | 03:54 PM
Sudia247's Avatar
But even with the engine in, the front end was really stiff.. Both truck I have had the engine out when I tested them. One didnt flex at all and the other truck compressed a couple inches when id really try bouncing it. both are regular cab long bed with a 12v. I dont see why one would be so much stiffer if there from the same truck, same spring size and everything.
Im not sure which one I want to put in..
Old Aug 11, 2011 | 04:12 PM
NadirPoint's Avatar
Springs wear out and get soft with use. The ones you found compressing more were just worn more. If I was building a truck from the ground up I'd install new progressive coils from one of the reputable distributors of those items, Kore, Carli, Thuren.
Old Aug 11, 2011 | 05:26 PM
Sudia247's Avatar
Yea I definitely would put some Carli spring in but Im already dropping enough cash into this truck, Im only rebuilding it because I rolled it and thought Id make it nice since im tearing a lot down anyways. So im gonna keep some spring for now, what would you think, should i put in the soft ones now or the stiffer ones till i get new progressive springs?
Old Aug 11, 2011 | 05:41 PM
NadirPoint's Avatar
If they came from the same or similar model trucks and I wasn't sure when I'd be upgrading them, I'd keep the stiffer (less worn) ones.
Old Aug 11, 2011 | 05:54 PM
x2
Old Aug 11, 2011 | 07:44 PM
Sudia247's Avatar
x2
Even if I dont tow that often and drive off road half the time?
Old Aug 11, 2011 | 08:05 PM
Springs won't get stiffer over time, only softer. Too soft of a spring will make the front end feel spongy, can cause you to bottom out on or off road, and just make the truck handy poorly all around.
I went and jumped up and down on my front bumper eariler and the springs barely moved at all (I'm 230lbs btw) and it rides fine down the road. Not exactly a scientific test but you get my point Lol.
Old Aug 11, 2011 | 08:24 PM
Sudia247's Avatar
Yea that makes sense. Thanks for jumping on your bumper to too see. Im 210 so it sounds like those are my stiff springs, I was just thinking they were **** or something, but your logic makes sense. Thanks, Ill be putting in the stiffer ones then.
