help please. widows will not go up
Old Aug 9, 2011 | 09:11 PM
buckeyejosh3's Avatar
Default help please. widows will not go up
hey i tried to put my power windows up tonight, and there was nothing.. i check the fuze it looks good, plz any help will be appreciated.
is there anything else that could have blown?
Last edited by buckeyejosh3; Aug 9, 2011 at 09:11 PM. Reason: Automerged Doublepost
Old Aug 9, 2011 | 10:30 PM
Red_Rattler's Avatar
High Tech Redneck
neither window or just one? can you hear the motor doing anything at all? test light at the swich for power then down the line
Old Aug 9, 2011 | 10:34 PM
both windows.. and there is nothing. no motor or nothing.. did some research and also found out that my blower motor isnt working...
Old Aug 9, 2011 | 10:36 PM
BIGREDGOAT's Avatar
fusible link man! one burned up!!! I have had living hell with fusible links!!! rewire all of that. There is a sticky over replacing all the fusible links with maxi fuse's
Old Aug 9, 2011 | 10:46 PM
thanks. is it hard to do? can you get new fusible links? where there located at?
Old Aug 9, 2011 | 10:56 PM
BIGREDGOAT's Avatar
No its not that hard. And Im not sure if can get new ones or not. And they are are located on the drive side, on top of the fender.
And no problem man!
Old Aug 10, 2011 | 12:41 AM
Stosch's Avatar
Hey man, you can make fusible links easily. Get some wire, wire crimpers, two terminal crimp connectors (which you can fit a maxi fuse on... so big enough), and your maxi fuse. Wham! there you have it. But just grab a multimeter or test light, see if you have power going to the motor if you don't it's probably your wiring. If you do check for ground, if you have a reliable ground, it's your motors. Which is not probable since they both went out at the same time, unless you have bad luck. As well check the listing of all fuses, because sometimes windows or just random accessories can share fuses. [Example: stop light, ignition and windows can share the same fuse] so read through all the fuses.
Old Aug 10, 2011 | 01:14 AM
sweetv8s10's Avatar
I replaced 2 of mine with circuit breakers and they work great and u never need to replace fuses.
Old Aug 10, 2011 | 06:18 AM
Glantz496's Avatar
If not the fusible link then check the actual switch...its not too terrible to take apart....I've had the same problem with mine and i had to solder the ground pin to make a better connection....has been working good so far
