fluid leak
Old Aug 9, 2011 | 08:12 PM
mgtexas's Avatar
Default fluid leak
Hey, need ideas. got a lot of luid leakage below or below and in front of the power steering dipstick and in the steering gearbox area and covering all the way back to the trans. i cannot see where it is coming from or find anything loose. the fluid is thinnner than eng oil but it is so covered and dirty that I cant tell be if it is power steering fluid for sure. i thought that maybe the crank case vent had maybe gone nuts but it does not appear to have done so. fluid levels are normal. what do yall think. truck is a 99 2500 5.9 with auto and 4wd. thanks.
Old Aug 10, 2011 | 02:20 AM
dukeboy_318's Avatar
heat exchanger, tappet cover or vaccum pump seal are all possible things to leak in that area. It could even be bad blow by. I say washed it good and try to monitor it after you run the motor to see what the leak is.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
01cummins4ever
Dec 28, 2014 07:43 PM
