3200 rpm
Old Aug 9, 2011 | 03:40 PM
RollinCoal91's Avatar
Default 3200 rpm
i have been trying for about an hour to get out that back hex screw the last of the 4 but the throtle screw is in the way how do you get it off? 1991 cummins injection pump
Old Aug 10, 2011 | 08:06 AM
Glantz496's Avatar
the throttle screw is usually held on with a nut....break that loose and then you should be ok to turn it out with a screwdriver....dont try to put it back in without taking the throttle screw out...9 times out of 10 you end up stripping out the hex bolt
whoops....just saw you meant to take out.....but it still applies....i managed to take it off with the throttle screw in but i had a 5mm long allen wrench in a socket....and almost did strip the screw out so feel along the back of the throttle screw and you should find the nut
hope it helps
Old Aug 10, 2011 | 12:41 PM
i went to take out the allen screw and it was already stripped..... any tips???
Old Aug 10, 2011 | 01:05 PM
Glantz496's Avatar
if there is some bit left you can try to maybe put a slightly larger size allen head in...make sure that idle screw is out definitely this time and try to tap your allen wrench in with a hammer as far as it will go.....i hope there's a bit of edge left to get it
anyone else with any ideas?
Old Aug 11, 2011 | 03:19 PM
Thekingrulz69's Avatar
Ya. I also hear that parts for a VE are near impossible to find also. So be super careful when you actually take it apart. Have a friend there to help you put it back together cuz its a 3 handed job.
Old Aug 11, 2011 | 07:06 PM
tower_ofpower's Avatar
Default 3200 rpm
Try an Allen head with the rounded ball on the bottom, it'll let you get fully into the socket with out being DIRECTLY square with the head which is impossible... I actually chewed into the side of the AFC a little bit and bent my Allen wrench to fit into the head squarely
- Sent from my iPhone using Tapatalk
Old Aug 12, 2011 | 06:22 AM
Glantz496's Avatar
The only thing i don't like about the ball head allen wrenches is that it seems that they strip out more than the straight ones.....of course that never stops me from using them first because they're so nice
Old Aug 12, 2011 | 11:19 AM
1993firstgennewbie's Avatar
My screw is completely striped what should I do?
Old Aug 12, 2011 | 11:31 AM
Glantz496's Avatar
if it's completely stripped and your bound and determined to get in there...i can think of a couple things but i can't guarantee any success with it being that close to the motor.
1. try to slot the allen head somehow and turn it with a screwdriver
2. try finding a pair of vise grips that will fit in there
3. try to knock the head off the screw and deal with trying to get the rest of it out once you remove the top
4. Leave it and just tighten the rest and hope it doesn't leak
That's about all i can think of right now...maybe someone else has an idea or dealt with this before
Old Aug 14, 2011 | 04:43 PM
i drilled the top of the screw out and then pulled the top off and the rest of the screw came out easy, however i drilled into the top cap of my pump but i found a new one for $150
