turbo
Old Aug 9, 2011 | 01:50 PM
1989w250's Avatar
Default turbo
If i have a none i/c 12 valve do i want a 16cm exhaust housing or a 12cm exhaust housing
Old Aug 9, 2011 | 05:31 PM
white93's Avatar
The 12 is good if you have a 5 speed. Get the 16 if its an auto. You only need to spool it once with an auto and it breathes better at higher rpm.
Old Aug 9, 2011 | 08:16 PM
RSWORDS's Avatar
Good advoce there.
Old Aug 9, 2011 | 10:38 PM
901stgen's Avatar
The 16 is soooo laggy from a standstill though. But it is better at high rpm's.
Old Aug 9, 2011 | 11:33 PM
geddy's uncle's Avatar
How bout a 14?
Originally Posted by white93
?..Get the 16 if its an auto....
His sig line suggests automatic "...3-gauge pod..." including trans temp. Not a guarantee, but, I'd bet 38cents on an A-518 in there
Last edited by geddy's uncle; Aug 9, 2011 at 11:33 PM. Reason: Automerged Doublepost
Old Aug 10, 2011 | 01:11 AM
sweetv8s10's Avatar
Not if its a 1989 it would have a 727
Old Aug 10, 2011 | 02:45 PM
white93's Avatar
His sig line suggests automatic "...3-gauge pod..." including trans temp. Not a guarantee, but, I'd bet 38cents on an A-518 in there[/QUOTE]
I was thinking auto myself but I have a getrag and have a temp gauge too.
Old Aug 10, 2011 | 04:43 PM
sweetv8s10's Avatar
Im confused it would be a 727 auto unless he changed to overdrive which didnt come out until I think 91.
Old Aug 10, 2011 | 06:33 PM
white93's Avatar
It probably is a 727. I meant to quote just the part about the trans temp gauge but messed it up somehow.
Old Aug 13, 2011 | 01:50 PM
Gas's Avatar
Gas
So how are the 14cm's with the automatic?
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
