Transmission and F/P question 01' ram
Old Aug 8, 2011 | 10:43 PM
Tweaker727's Avatar
Default Transmission and F/P question 01' ram
So i think my issue is i've set the cable advancement to far on the T/V cable, but it shift's just were i like it out of first, but it ends up missing second gear completely, and just goes straight to third gear. If i set it to the other way, it holds 1st until about 2300 RPM.
When it shifts into third gear, it also flare's up before it fully " Engages " in said gear,
No slippage what so ever, it just plain moves under lockup in ANY gear, ( minus the hold up in first once in a while )
Gauge :
My Di-pricol F/P gauge buzzes, which annoys the heck out of me. tightened the fittings and bleed them, still same problem.
Thanks
Nick
Old Aug 10, 2011 | 02:43 PM
Tweaker727's Avatar
31 views and nothing ? Not even a tough luck ?!
Old Aug 10, 2011 | 08:38 PM
Nutty Jeeps's Avatar
I as well am having tranny problems, I believe mines electrical tho.... Dealer can't even figure it out........... I know how your feeling my trucks been down for about 7 weeks now because of it
Old Aug 10, 2011 | 08:45 PM
sde67's Avatar
check cam sensor or take clean the plugs on pcm and check all grounds expecilly on on pass side that plugs in
Old Aug 11, 2011 | 08:12 PM
mike12321's Avatar
governer pressure solenoid
