Want to switch my new 06 5.9 to better oil
Old Aug 7, 2011 | 07:21 PM
Rob T's Avatar
Default Want to switch my new 06 5.9 to better oil
how much oil does everything take and what brand should i use its a auto
Old Aug 9, 2011 | 09:59 PM
articcummins's Avatar
I like the Rotella, it look like it get dirty slower than the other oil I try. I check some review on the net and they all say that it's a good brand. The 5.9 take around 12 liters. I use it in my tractor to.
Old Aug 9, 2011 | 10:56 PM
wildbill's Avatar
https://www.dieselbombers.com/dodge-...ies-types.html
Old Aug 9, 2011 | 11:00 PM
Red_Rattler's Avatar
High Tech Redneck
mobil delvac synthetic in the motor, amsoil in the axels tranny and transfer of mine
Old Aug 10, 2011 | 06:57 AM
MurphyStrut's Avatar
I use 8 quarts of rotela and 4 quarts of Lucas oil stabilizer. I also put a pint of seafoam I the crankcase and run it for a 50 miles or so, that really seems to get the old oil to drain well. I've got about 170k and still going strong!
Old Aug 10, 2011 | 08:06 PM
KingCopa's Avatar
I ran the Rotella and found this webpage and after reading it I changed for my last oil change that I did a week ago. Not sure on any benifits but figured it couldn't hurt..not to ruin anyones reading I want with the #2 result. Here is the link if you care to read it Turbo Diesel Register Tech: Lube Oil, Religion, Specifications and the TDR
Old Aug 11, 2011 | 09:22 AM
Heath's Avatar
Authorized Amsoil Dealer
I use synthetic throughout
Old Aug 11, 2011 | 10:48 PM
I look at the result of the test, I found other test that saying different stuff but you never now who work for who so if a brand work for you use it. My truck run on Retella since I have it, is close to 300 000 miles, the only part part i change (out of brake and stuff like that) on it is the priming pump, I uprade it for a AirDog. Have a nice day.
Old Aug 11, 2011 | 10:50 PM
High Tech Redneck
I can only guess as to what brand...
Old Aug 17, 2011 | 01:39 PM
AABEAR's Avatar
Thes test was oil that was sent in to be tested with only a number on the bottle so that way they could not be leaning one way or the other.
