nv4500 questions
Old Aug 7, 2011 | 02:03 PM
lauber_03's Avatar
Default nv4500 questions
would a nv4500 out of a 96 chevy bolt up to a 89 12 valve? or do you have to use an adapter
Old Aug 7, 2011 | 04:41 PM
cummin_un_glued's Avatar
FormerVendor
different bell housing and input shaft but then yes it would bolt up, u may have to change the engine backing plate i'm not 100% on that one
Old Aug 8, 2011 | 04:34 PM
Mark Nixon's Avatar
So many variables here.
Do you plan to swap to a Dodge Diesel input and bearing retainer?
Chevy uses a 1-1/8" by 10 spline input, Dodge uses a 1-1/4" X 10 spline input.
You also need the '94-'02 Dodge block plate, starter, flywheel and clutch.
You CAN put the Chevy bell and block plate on, then run a Chevy style flywheel, clutch and starter, but if you don't happen HAVE the Cummins-to-Chevy stuff, the Dodge stuff is much, much cheaper to get.
I've seen the Chevy flywheels SELL for $800.
Also, the more commonly available Chevy block plates that are out there, tilt the engine 15 degrees to the passenger's side.
Mark.
easttn12valve
Ford Powerstroke 08-10 6.4L
11
Apr 15, 2015 09:47 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
