cummins motor oil
Old Aug 6, 2011 | 05:15 PM
trentonwest29's Avatar
Default cummins motor oil
is it ok to run mobil delvac 1300 15w-40 motor oil in a 1994 dodge 12v cummins?
Old Aug 7, 2011 | 01:03 AM
dezzrats's Avatar
It will love Delvac 1300. Don't forget some 2stroke oil to treat the fuel, about 1oz per gal, and get a real Fleatgaurd oil filter, don't cheese out on a Fram or something.
Old Aug 7, 2011 | 03:27 PM
ok i've never heard of two stroke oil to treat fuel?
Old Aug 7, 2011 | 04:08 PM
dezzrats's Avatar
Due to smog regs they take out all the good stuff from diesel these days. You need somthing to lube your pump.
I use the Walmart Super Tech 2 cycle oil for boat motors. Buy it in the gallon jug and use two of the 16oz jugs in each fill-up.
Old Aug 7, 2011 | 08:13 PM
is it safe to do it will it mess anything up or make it smoke more? but the more smoke the better
Old Aug 7, 2011 | 10:22 PM
dezzrats's Avatar
Just gives the fuel a little bit of lube quality. Helps out your pump and the rest of the motor. You won't notice any more smoke from it.
I put a little too much (like 4-5oz per gal) in my 06 Superduty one time and I think it lost a little power, but that is a whole different animal. I don't think you could put too much 2stroke oil in a gen 2 cummins.
Just cheap insurance with today's Ultra low sulfur fuel in an old truck.
Old Aug 8, 2011 | 12:13 AM
geddy's uncle's Avatar
Mobil delvac 1300
Chevron delo 400
Shell rotella all in 15w40 are good oils.
If you want extended drain intervals, (while still doing a filter at 3k) delvac-1 or rotella t-6 full synthetic 5w40 are permissible, as well.
Old Aug 8, 2011 | 06:59 AM
ok thank you
Old Aug 8, 2011 | 11:21 AM
South Tx Coal Roller's Avatar
I use Valvoline Premium Blue and 2 quarts Lucas oil. I've seen first hand the things that Lucas oil can do for an engine and I was impressed.
I use the Super Tech 2-cycle oil also, roughly 1oz per gallon. It actually quieted my pump down some and it idles smoother. It deffenetly won't hurt anything and like dezzrats said it's cheap insurance.
Old Aug 8, 2011 | 08:22 PM
ok im gonna use the 2 stroroke oil thank
