Warped rear drums
Old Aug 5, 2011 | 09:52 PM
racin_ny's Avatar
Default Warped rear drums
I have a 98 12 valve 8800 gvw 4x4. In the last year I have gone through two sets of the $55.99 Advance Auto rear drums. I'm tearing into it tomorrow and I was wondering if anyone had any idea of what's going on. When the first set warped I adjusted the rear proportioning valve to give less breaking in the rear. I made sure they weren't adjusted up too tight and the e brake cables seem good. I use the ebrake every time I park. The pads were changed a year ago they came from Carquest. Can anyone recommend a brake shoe / drum combination that works well for them? I do not do any hauling or towing. Thanks for the help in advance.
Old Aug 6, 2011 | 10:42 AM
South Tx Coal Roller's Avatar
What condition are your front brakes in?
Old Aug 6, 2011 | 03:32 PM
racin_ny's Avatar
Pretty good they were new about 8 months ago new calipers, pads disc's and flex lines.
Old Aug 7, 2011 | 08:32 PM
racin_ny's Avatar
Pulled the rear brakes all apart. Turned 1 drum in on warranty because it was warped. Changed both rear wheel cylinders and springs and hold downs. Shoes look good, made sure the adjusters were free. I guess we'll see what happens.
Old Aug 14, 2011 | 10:58 AM
Jerroh's Avatar
ok my experience on this and things i have heard are that using the parking brake while the brakes and drums are still hot will cause warping. I had warped drums before and since i stopped using the parking brake i havent had them warp since. I am going to guess that using top quality pads and drums might also eliminate the problem.
Old Aug 14, 2011 | 08:37 PM
tiremann9669's Avatar
I think Advance Auto is your problem, try some NAPA or Carquest drums
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
Max713
Apr 17, 2015 01:20 AM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
