just put 35s on my truck now rides like crap need help
Old Aug 5, 2011 | 08:46 AM
kgsquad1's Avatar
Default just put 35s on my truck now rides like crap need help
ok so i had a 2 inch rough country leveling kit professional installed along with nitto trail grapler mt 35 12.50 17 on stock rim put no they had 70 psi in the tires i droped it down to 45 and the ride smoothed out a lil bit not alot should i drop pressure down some more or take it back to them and say somethings wrong thought about new shocks maybe?? steering stabalizer????? any input will help i did have a front end aligenment done its on a 2011 cummins 2500 crew cab
Attached Thumbnails just put 35s on my truck now rides like crap need help-resampled_2011-08-02_16-28-00_982.jpg
Old Aug 5, 2011 | 09:12 AM
NadirPoint's Avatar
Default Bad Idea
Originally Posted by kgsquad1
ok so i had a 2 inch rough country leveling kit professional installed along with nitto trail grapler mt 35 12.50 17 on stock rim ...
So did they get professional training on how to turn a wrench or how to correctly perfom Ram truck suspension upgrades, including all the required parts to do it properly?
Because if all they did was install pucks, they took your labor money in exchange for a truck with tires too big for the wheels and a front end ready to start doing the death wobble dance as soon as the joints and bushings get worn out enough, which won't be too long from now at this point.
Old Aug 5, 2011 | 09:17 AM
kgsquad1's Avatar
they did a coil spacer its not crazy bad just a lil bumpy driving alot of lifted trucks before and they have all been smooth riding i duno if it was the actual kit that they putin just sucks or there work just sucks i have no problem taking it to a different shop and having something done but i wanted to make sure it just wasnt tire pressure or that i kept the stock shocks on the truck
Old Aug 6, 2011 | 08:19 AM
bluedieselram's Avatar
reusing stock shocks with a leveling kit wont mess anything up,you should take it to another shop and have the alignment checked
Old Aug 6, 2011 | 08:40 AM
NadirPoint's Avatar
Default Leveling Done Right
I've said this before in several other threads, and I'll continue saying it here again, just for the record: A correctly done leveling kit with either springs or pucks involves at a minimum:
1) Control arm eccentrics full forward.
2) Adjustable track bar ~1" longer to center the axle
With big tires you are also going to want:
3) Steering brace
4) New or better stabilizer
And to do it all right for best results:
5) New 1/2" longer control arms
6) Longer shocks
7) Longer sway bar end links
8) Drop pitman
And don't forget to install new ball joints and tie rods in case you've already been driving it with just pucks for too long.
Old Aug 6, 2011 | 08:46 AM
kgsquad1's Avatar
hey man i appreciate all the info ive been driving it like this for 4 days now the guy has pissed me off iam order a 6 inch suspension lift with all new stuff iam add steering stablizer into it as well and ive had the aligenment done once allready but iam do it agian after i pull that level kit off and demand my money back foir level kit i know iam not going to get labor back from them but iam return the part any info on what you think is a decent lift kit
Old Aug 6, 2011 | 09:10 AM
NadirPoint's Avatar
I've got mostly Thuren parts for my '07 because I believe he makes some top quality stuff. But you really won't go wrong with most any, Kore, Carli, or even the cheaper brands as long as it includes all the necessary parts and is installed and set up correctly.
Old Aug 6, 2011 | 09:44 AM
kgsquad1's Avatar
thanks man i appreciate it iam llok them up i dont mid payin a lil bit extra if its good quality you get what you pay for
Old Aug 8, 2011 | 12:02 PM
kgsquad1's Avatar
ok so i found the p;roblem the guy did the whole instal wrong took bushings out and everything so i just order a pro comp suspension lift and will be installed next monday cant wait and for that guy hes got hell coming to him tommorow morning
Old Aug 8, 2011 | 05:09 PM
make sure ya have recicts and pro comp lifts are worth the money
