spool aid just for 03+ trucks?
Old Aug 5, 2011 | 01:20 AM
blazier18's Avatar
Default spool aid just for 03+ trucks?
was reading on cummins forum about spool aid and seemed to just be on common rails for those who could find the kit or had enough skills to make the kit? if it is just for common rails i wonder if it could be used on 12 and 24 valves? if theres no kit for it but a possibility for it to happen belive me! when i get my truck here and payed for and tore down and back together i will find a way to make a spool aid if at anyway possible and be more glad to make for others after u see results of mine if any interested. now there sayin up pipes? there takin about intercooler pipe to intake manifold? if so i could find a way to drill hole and weld 2 different pipes with even flow smooth bends to #1 and #6 cylinder freeze out plugs! may tap it for water meth jets also. seems his egts went down a 180 at 70 mph and 50 at wot and gained almost 4 seconds spool up at a brake stall. theres a dyno video im goin to go watch now! if by anyway possible to be made please comment back! and if tapped for water meth surely would see larger drops in egt and gains in hp. and very quick spool up. this is just a wild hair up my **** please excuse me if i sound dumb! im also lookin into a performance intake plenum and manifold since i wont be porting intake side on my head hoping for good butt hp and lower egts then im expecting!
Old Sep 1, 2011 | 09:55 AM
K80's Avatar
K80
Spool Aid..... - Competition Diesel.Com - Bringing The BEST Together
Read this thread. 12V heads dont have the freeze plugs, 24v heads if i read this right were the first to start that. Plus the VP gets in the way of the #1 plug, so only #6 will benifit.
Old Sep 1, 2011 | 10:45 AM
Farmboy 2.0's Avatar
Yep is pretty much built and designed for just 03-07 5.9L and 6.7L cummins as well
Old Sep 1, 2011 | 01:56 PM
blazier18's Avatar
mine is p pumped
Old Sep 1, 2011 | 02:15 PM
Still wont work because of the pump is so damn big i think
Old Sep 1, 2011 | 02:34 PM
1st_gen_puller's Avatar
put a a CR head on your p-pumped vp truck... lmao... frankenstein!!!
Old Sep 2, 2011 | 09:18 AM
K80's Avatar
K80
I think your right. It wont work on a vp because its big so i'm sure it wont work with a p-pump. But maybe some crazy piping might get it done.
Old Sep 2, 2011 | 09:26 AM
Yeah i think there is a better chance on a vp truck than there is on a p-pumped truck
Old Sep 2, 2011 | 09:48 AM
K80's Avatar
K80
Scott, Do you know of anyone else having these besides rollin smoke diesel? I want to call them to check on lead time since they are all made to order.
Old Sep 2, 2011 | 09:51 AM
No i dont, Was that Rolling Smoke that had that thread on comp d? Or did they buy that guys design i wonder?
