standard RPM
Old Aug 4, 2011 | 03:19 PM
onlystock's Avatar
Default standard RPM
Having an only stock truck it came with no tach. I amm going to get an ISSPRO. It is intercooled, and I have the plug under dash by fuses.
My question is how many rpm's does this 91.5 dually go?
ISSPRO has tachs for 0-3k and 0-4k thanks
Old Aug 4, 2011 | 03:59 PM
1STGENFARMBOY's Avatar
get an 0-4k for room to grow later on.
Dar
Old Aug 4, 2011 | 04:09 PM
onlystock's Avatar
thanks dar. with no speed ups the 3K sounds like more accurate
Old Aug 4, 2011 | 09:53 PM
white93's Avatar
If your just using the truck as a dd and towing I would get the 3k because its more accurate, It's what I have in my dually. Get the 4k if your going to use the truck for play.
Old Aug 4, 2011 | 11:03 PM
Mine is a DD and a HEAVY tow rig, but i'm glad i got a 4k cause a can burry a 3k
really quick.
but if your not gona do any mods at all then a 3k is more accurate for shure.
Dar
Old Aug 5, 2011 | 01:46 AM
cumminsblazer's Avatar
in my opinion i would go for the 4k because most likely you are gonna get a 3200rpm spring cause its the best mod u will ever do ha ha my tach is a little over kill but i had a gasser motor before so i got a tach that goes to 10,000k ha ha but i never get above 3500
Old Aug 5, 2011 | 10:13 PM
Richie O's Avatar
I have a 4k tach in all 3 of my trucks. They all have the stock gov spring and I can still hit 3500 rpm's. Don't get a 3, you will outgrow it. Your talking a full sweep 270 degrees or so for only a 4 k tach. Its plenty easy to read. Its not like its a 10k tach with the numbers close together.
stump
5.9L CR Performance
Jun 11, 2015 09:52 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
dutchsupreme
Dec 18, 2014 01:44 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
