5'' Lift Track Bar Options?
Old Jan 1, 2008 | 08:14 PM
Monster Truck's Avatar
Default 5'' Lift Track Bar Options?
Right now I have a drop braket I guess you can call it for the track bar that came with my 5'' lift so you can still use the stock bar, well this setups sucks and the braket keeps comeing loose and what not, Ive tried everything and its just a stupid setup so I was wondering if there is a track bar out there that will make it so I can **** can the drop braket and go to the stock location on the frame.
Thanks in advance.
Old Jan 1, 2008 | 08:26 PM
LOGANSTANFORTH's Avatar
are you running a drop pitman arm??? this makes a difference wether you want to go back to your stock mount or not, if your trac bar and steering aren't in the same plane you will get a nice case of bump steer.....
Old Jan 1, 2008 | 08:29 PM
EMD567's Avatar
I believe someone out there makes an adjustable track bar. I'm not sure where though, hopefully someone chimes in with a link.
Old Jan 1, 2008 | 08:51 PM
It does have the drop pitman arm on it.
Old Jan 1, 2008 | 09:53 PM
do some looking and make sure the tracbar and steering link are in the same plane if you take the drop bracket off the tracbar....cause if i remember right, they wont be....
Old Jan 1, 2008 | 11:14 PM
I have to run a pitman drop arm though dont I?
Old Jan 1, 2008 | 11:36 PM
yes if you want your tie rod angles right.....
Old Jan 2, 2008 | 10:25 AM
So sounds like I gotta make this braket work.
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
motormayhem
Nov 1, 2014 01:24 PM
JJ Diesel
Oct 6, 2014 11:21 PM
