headlights
Old Aug 3, 2011 | 10:13 PM
bsnyder47's Avatar
Default headlights
I am wondering what headlights and or bulbs i can get to have bright headlights. I had 80/100 bulbs in my stock headlights then I bought projector headlights at a truck show i put them in and they suck they are made by spyder never buy them they wont take them back either I was thinking of getting 100/120 bulbs for my stock headlights let me know what you guys have I wanna see at night
Old Aug 3, 2011 | 11:03 PM
crusty_critter03's Avatar
projector headlights are primarily designed for HIDs. ive found a few places that you can get HIDs for 150 or so online. try ebay for instance. also note. i personally do not have HIDs (yet) but have been 'told' not to purchase a set with high/low beams. something about them not lasting as long. either way. HIDs are bright as all get out an i dont know that high beams would even be neccessary.
Old Aug 5, 2011 | 11:59 AM
1993firstgennewbie's Avatar
what do you think the brightest standard bulbs are.
Old Aug 5, 2011 | 01:59 PM
daveO's Avatar
I did the sport light mod on my truck with the suvlights.com harness. I wish I would've done this the first time I upgraded my lights.
Old Aug 5, 2011 | 03:16 PM
South Tx Coal Roller's Avatar
What is the sport light mod?
Old Aug 5, 2011 | 04:00 PM
daveO's Avatar
The sport light mod involves retrofitting the later (I forget which years, I think 99+) "sport" model lights. These lights have 2 bulbs instead of one. With the suvlights.com harness, it has both lights on for both low beams, and high beams. I'll head out and get some pics.
This is a link to the harness I used.
suvlights.com Dodge Ram (Sport Headlights) Super Heavy Duty Conversion Harness w/4 relays 9004
The nice thing about the harness is that it's a direct plug in, no splicing needed. It also uses relays so that the power for your headlights no longer runs through your headlight switch.
Old Aug 5, 2011 | 04:47 PM
Nice! Thanks for taking the time to snap a pic. Are the sport headlights a direct swap?
Old Aug 5, 2011 | 06:10 PM
daveO's Avatar
No problem! Not exactly a direct swap. You need to remove some sheet metal from behind the headlight so that the 2nd bulb will fit back in there. Other than that, all the mounting bolts line up exactly.
Old Aug 5, 2011 | 07:28 PM
Sounds simple enough to me. Thanks again man
Old Aug 5, 2011 | 07:41 PM
daveO's Avatar
No problem.
