How To Pull Codes
Old Jan 1, 2008 | 06:12 PM
powerfan985's Avatar
Default How To Pull Codes
i have a 1998 24v and im having trouble with me rebuilt transmission. i was wondering if i can pull engine codes myself without a scanner? i tried on/off/on/off/on with the key and didnt get anything to happen.
Old Jan 1, 2008 | 06:15 PM
The on/off trick wont work on a 98....and doesnt work very well on any other year either.
You need a OBDII scanner or have access to some type of programmer - a Smarty for example.
Old Jan 1, 2008 | 06:18 PM
Wyatt Earp's Avatar
A Smarty costs about the same as a good scanner and you get the added benefits so it makes good sense.
Old Jan 1, 2008 | 10:59 PM
JSPulliam21's Avatar
Or, you can rent a scanner from Auto Zone. They charge you the full price, and you get it back when you return the tool.
Old Jan 16, 2008 | 09:31 AM
Mopar1973Man's Avatar
Take a peek...
Key method...
http://mopar.mopar1973man.com/2002%2...rror_codes.htm
OBD II error listing for 98.5 to 2002 Dodges (PDF File)
http://mopar.mopar1973man.com/2002%2...or%20Codes.pdf
Then my other tool for OBD II error codes... Lot cheaper than most tools but does a lot more than read error codes... ScanGauge II is much cheaper than a $600 smarty...
http://mopar.mopar1973man.com/2002%2...scangauge2.htm
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
Renowest48
Dec 14, 2014 08:36 PM
james2562
Nov 2, 2014 08:31 AM
Altonlee
9
Oct 8, 2014 02:31 PM
